メインコンテンツにスキップ
Why doesn't it power on
My laptop stopped showing life signs( no lights,no bootup) then i opened it and removed the power button and plugged in the ac cord and it showed lights…but i couldn’t turn it on so i plugged the power button and it didn’t show any light more…help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
You wrote "power button". Did you mean "battery" ? If that is the case, how long did you wait, after plugging in the battery charger, before attempting to turn it on.
If the battery is completely flat ( no charge) there will be NO residual power on the motherboard. In this case it may take several seconds before it will switch on. So plug in charger, lights come on, wait about 10 seconds or so and then try to switch on the laptop.
さんによる
I clearly meant the power buttom
さんによる
The battery is fine the...if i plug the power button in the laptop doesn't show life...if i unplug it, it shows the charging light but then i can't turn it on because the power button is unplugged
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Power button defective.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It works! But it makes the lights from my laptop dissappear...does anyone now how to turn a laptop on with the keyboard or something
さんによる
コメントを追加
回答を追加する
Matteo Mireuta さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 110
