After installing a SSD (250GB) in the optical drive bay...?
After successfully installing a SSD (250GB) in the optical drive bay, what should I do with the applications, MacOS, etc. left on the original 1TB hard drive?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Locate the OS installer either on your HDD or re-download it from the Apps Store. Using Disk Utility prep the SSD with a GUID partition with a Journaled file system.
Install the OS onto your SSD, then at the end of the installer run the Migration function to move over the User account & Apps (not your data!)
Done! Your SSD should now be the boot drive. Make sure your Apps are working.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 32
