Are iPhone 5 s and 5 se the same case?
is the iphone 5 s and 5 se the same case?
I say yes. The only thing that might be an issue is microphone ports. Past that they should be compatible.
このアンサーは役に立ちましたか?
If the OP would believe your answer would happily go buy the wrong housing, as the iPhone 5 and 5S have in common the size and little more than that. Can you explain what's the point of supplying wrong misguiding infos ?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 42
4 件のコメント
What do you mean by “case”? Do you mean like a housing for the phone or a protective case?
Owen Baker さんによる
I think he means the rear casing where all the good stuff is held. If so, then I will say yes. The only thing that might be an issue is microphone ports. Past that they should be compatible.
JacksKidding さんによる
Also, for the protective case, yes to that.
JacksKidding さんによる
Case - the back enclosure, the significant part of the phone, the back plate minus the screen, the body of the phone that holds all the guts. Case. As they describe the part on iFixit the "rear case". I have since learned that the 5 5s and SE are all the same case. But thanks for your reply all the same Owen.
Scott Forbes さんによる
