メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
Big blue stain across phone screen, any solutions?
Picked up my phone because it was ringing in the shower, around thirty minutes later i find a big splotch of blue stain across the screen. Probably bc i have an open crack in the top right corner of my screen. Trying ventilation and considering direct heat from a table lamp in order to remedy problem. Not sure if it would work, any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Yes, seems you have water that has got into the screen and maybe into the device.
You need to switch the iPhone off now and have it checked out. If it is just the screen, that can be replaced, but if water has got into the phone, the phone will need to be dismantled and the circuit board cleaned to remove corrosion and residue.
This is usually done by putting the main circuit board through an ultrasonic cleaner. Be aware there may be components on the main circuit board which have been shorted out, so this may or may not cost you more than the device is worth.
Certainly worth trying a new screen first though.
Here is the iFixit screen replacement guide…
iPhone SE スクリーンの交換
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
This is a very helpful response but the only thing is that they had a lot of problems with the iPhone SE. Since its a bigger processor than the 6 and 6s inside the size on and iPhone 5, it does tend to have a lot of flaws after screen replacements and other component fixes. Just be carful and if the phone goes crazy on you don't be surprised!!! best of luck!
さんによる
I have not found iPhone SE's to be any more difficult to repair for a screen replacement than any other iPhone. I do use a beautician magnifying lamp and a microscope if I need to
さんによる
コメントを追加
As u said the screen is damaged/ so its possibly the screen that needs replacing any additional pressure on the screen when it's already broken will display marks and possibly stop it from working
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Johnny Yang さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 24
過去 30 日: 116
今までの合計 13,309
