メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1538回答 すべてを表示
Is the Optical Drive Daughterboard swappable?
Howdy. This is more of a wanting to know and if so type question. Basically I know that on PS4 the optical drive and motherboard are paired. But from my understanding, the optical drive has a daughterboard that has the chip that pairs with the motherboard. I am wanting to know if I can move the daughterboard from the old optical drive and put it on a new optical drive or does the daughterboard and motherboard have to be replaced together?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
選択されたソリューション
As long as you have that large square chip from the original daughterboard that you can transplant onto the replacement daughterboard it will work fine. If you don't have that chip there is no way to pair the drive and the motherboard.
このアンサーは役に立ちましたか?
スコア 2
コメント:
PS4 CE-35888-2 Error Code fix. Don't you just have to replace the optical drive with a new one(same numbers 10 or 20) when you have the original daughter board? Asking because I'm in this situation. Really need help. Thank you!
さんによる
コメントを追加
最も参考になった回答
@car34 check with our friend @tronicsfix on here t “You CAN replace your optical drive! The trick is that you need to find an optical drive that originally had a daughter board with the same number (010 or 020) as the one you have. After you get it all you have to do is remove the board that came with the replacement drive and install the one that came off of the bad optical drive that you are replacing onto the replacement blu ray drive.” Nobody knows more about consoles than this guru!
このアンサーは役に立ちましたか?
スコア 5
コメント:
@car34 read this again :"need to find an optical drive that originally had a daughter board with the same number (010 or 020)"
さんによる
コメントを追加
The drive pairing can be retained by swapping the board, but the laser pickup calibration will be off and there is basically no way to recalibrate.
For most drives this shouldn’t be a big issue, the controller chip has some sort of self adapt range, but don’t expect the drive to perform as good as new.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I have Never ever seen an optical drive with a non removable PCB :)
however you will need to make sure the drive assembly and optical pickup are the same as the one for your consoles PCB
このアンサーは役に立ちましたか?
スコア 0
コメント:
It just I never done one and I wasn't sure how integrated it was. I couldn't find anywhere that would just say that they can be swapped. Only that the motherboard and daughterboard had to be replaced or having to marry the old chip on the new board.
さんによる
yeah the drive keys need to match but you can remove the paired PCB onto your new drive assembly. Sony use multiple drive assemblies and pickups depending on the revision of console the type of assembly and optical pickup should be printed on the parts
さんによる
Does this hold true for Xbox ones as well?
さんによる
@tyaczikx yes you need to swap the logic /daughter board. Think there's 2 or 3 ribbon cables. And two wires to unsolder. Red and black. Solder points are labelled r and b, So its easy if you know how. I've done it twice. First time was a reconditioned one second was brand new
さんによる
コメントを追加
回答を追加する
Carlos Ramirez さん、ありがとうございました!
統計データを表示:
過去 24時間: 9
過去 7 日: 49
過去 30 日: 206
今までの合計 10,110
