メインコンテンツにスキップ
Repair information and troubleshooting for the RCA Voyager III, a 7 inch budget tablet that uses Android 6.0 OS and can access the Google Play app store.
34回答 すべてを表示
Won't finish updating firmware
Basically, I turned it on. I turned on the WiFi. I started a firmware update. It's showing a black screen, with a ring in the middle. Along with a loading bar that says “installing system update". Every time the bar fills, it resets. Shows the RCA logo screen. And goes, right back to updating. I can't click on anything. And it's been about, 13 or so hours. Any suggestions, on what I should do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
1 件の回答
最も参考になった回答
It seems like you have something you shouldn't on the device. Bad app, virus, malware, etc. A normal update won't cause problems, even if you don't install it. Try starting up in "Safe Mode" and see if it happens in there. If it is one of those problems, it shouldn't happen when in that mode. You will then have to remove whatever is the cause to resolve the problem.
To get into "Safe Mode" please do the following.
1. First turn off the tablet.
2. Next press and hold "Power" until you see the manufacturers logo on the screen, then release the power button.
3. "Quickly" press "Volume Down" and hold it for few seconds until you see the message "Safe mode: ON" or something similar.
4. If you wanted disable it, simply repeat the steps above, and you should see "Safe Mode: OFF" rather than on.
Hope this will help you.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
It's not going to safe mode it just keeps restarting please help?
さんによる
@Susan Jackson A reboot loop can be a result of various issues, including corrupted drivers, faulty hardware, and malware infection, among others. Make sure troubleshoot everything. Or kindly check out the post. https://www.partitionwizard.com/partitio...
さんによる
コメントを追加
回答を追加する
Grim law さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 2,498
