メインコンテンツにスキップ
日本では1994年11月22日、北米では1995年5月11日、欧州では1995年7月8日にセガから発売された32bitの第5世代ゲームコンソールです。
22回答 すべてを表示
Game Disc Reads as CD, what should I do? please help
Every time I turn the console on WITH a game in it, it reads the cd as if it was an audio disc. It says its "checking disc format" then after it seems to attempt a load, it just stops and the cd ceases to spin.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
2 件のコメント
you sould try replacing the dvd drive and lazer
さんによる
Why would you suggest that? How do you come to that conclusion and how is the person going to do that?
さんによる
コメントを追加
1 件の回答
ベストアンサー
First of you should make sure that your laser is clean. Also make sure you see your laser move properly. If the cleaning does not work (some people use a commercially available laser lens cleaning CD) you should start thinking about disassembling your Saturn. Here are some really good instructions. Once you got this accomplished, you will find a little orange "dial" which is actually an adjustable potentiometer. It is just above the cable that connects the laser assembly to the circuit board. When you turn the dial counter-clockwise, the laser will seem to get dimmer, when you turn it clockwise you will notice that the disk/drive will start spinning. (here is a video to help you with the laser repair) That is where I would start. OF course, make sure that you MARK THE SPOT where you start from. MARK IT FOR SURE so that you do not lose the starting point. But, start cleaning your laser first. Good Luck.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
回答を追加する
elijah hewlett さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 5,071
