How do I clean a corroded door seal on a kenmore washing machine
How do I clean a corrode door seal on a kenmore he2 washing machine
Deborah Ellison the seal itself should not corrode since it is some kind of synthetic (rubber). If it corroded the metal behind the seal, clean it off with some emery clothes or steel wool and use some appliance enamel to apply over the metal. Then replace the door seal.
Post some pictures of your damage with your question so we can see what you see.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 60
2 件のコメント
Did you try a self clean?
Scott P. さんによる
This may not work I am not sure where in the door your talking about but if a self clean doesn't work try using a Q-tip
Scott P. さんによる
