メインコンテンツにスキップ
様々な種類のサウンドカード用修理ガイド
2の回答 すべて表示
Annoying static noise on realtek integrated audio
This has been an ongoing issue. The problem got temorarily fixed when It automatically installed an nvidia sound driver along with my video card, however after rebooting the problem promptly returned. Here’s whats going on: https://www.youtube.com/watch?v=FbOHncQs...
Before any of you ask, Yes I’ve tried reinstalling the driver, Yes, I’ve tried disabling the realtek driver and it refused to use the nvidia one.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Is nobody going to help?
による
When does this sound happen? Right after you power on your computer? Is it still there if you mute the sound with software? Does it ramp up according to your volume control? Does any other sound play, or is it only always noise?
による
Going to record and upload a video. It starts shortly after booting into windows then goes away when it starts shutting down. I am going to set the speakers to full volume in the video so you can hear it.
による
Did something change for this to start happening? Software install/update? Does any other sound play other than noise?
による
表示する 4 他のコメントを
コメントを追加
PCラップトップ用バッテリー
An easy fix for a big power boost.
ショップを見る
PCラップトップ用バッテリー
ショップを見る
1回答
最も参考になった回答
Hi @connor2003
good day
please list down your pc components, e.g. using laptop or desktop.....
if using desktop please list down the parts...
e.g. power supply, etc
sometimes this issues, can be due to some issues,
e.g.
OS issues,
Power supply not clean
soundcard issues
mainboard issues
grounding issues
try running for a long run with a linux live cd, and play some music for an extended time... are there any distortion?
この回答は役に立ちましたか?
スコア 1
コメント:
Dell Inspiron 3847 with stock oem dell motheboard
Intel core I5-4460@ 3.20 ghz
8 gb ram
Sandisk SSD plus 240 gb
EVGA gtx 1050
EVGA 750 N1 750 watt power supply
The sound card is built into the botherboard
the power supply, ssd, ram, and graphics card are brand new.
による
Hi Connor
Suggest you to update bios and test run in a "live linux environment"
https://www.linuxliveusb.com/
http://www.knopper.net/knoppix/index-en....
による
How is that supposed to fix my sound issues? For security reasons, I am not going to do that.
による
I end up buying a dedicated or external sound card to avoid the static noise issues.
による
コメントを追加
回答を追加する
Connor さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 11
今までの合計 125
