メインコンテンツにスキップ
Guides and repair information for televisions made by ProScan.
18回答 すべてを表示
Status light won't turn on, the won't work
I have a Proscan 33” LED TV (ATSC tuner). I came home and went to turn it on, and the status light flashed and clicked then shut off. I tried resetting. I reset it three times with no luck. Unplugged it as well and tried again. No luck. Idk how to check the mainframe or whatever its called or what to look for. Please help, gaming is what keeps me sane and I can't afford a new TV for awhile.
The model number is CN32XB720
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Hi @toxxic_carress ,
If you have a DMM (digital multimeter) or you know anybody who has one and who knows how to use it, use its’ Ohmmeter function check that the fuse and the surge suppressor on the Power board are OK.
You’ll need to remove the Power board from the TV to test the fuse and the suppressor
Here’s an image showing where the fuse (red box) and the suppressor (red arrow) are located on the Power board.
(click on image to enlarge for better viewing)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
@toxxic_carress
you want to start checking your power supply. For that you will have to remove the back and check the fuses on your board. Take some good pictures of your boards and post those with your question. That will allow us to see what you see. Also, we need to know the exact model number for your TV.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Lexi Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 347
