Will Activation lock be bypassed when we exchange the logic board?
If I buy a logic board (motherboard) on Ali Express and exchange it with the one of my phone will the iCloud lock be bypassed???
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sure it will..just make sure you don’t buy a too cheap board for parts that may be locked too. Unless the listing is very clear on its own, contact the seller to make sure the board is clean and network unlocked. Make sure the relevant home button will come together with the board to be able to use touch ID.
このアンサーは役に立ちましたか?
what will happen if i dont buy a relevant home button??
@lmn_munir If you have no button you'll miss both touch ID and the return to home feature and you'd have to adapt to use the assistive touch instead. As of late have started appearing in the market some bluetooth home buttons for iPhone 7/8 models, I've not yet tried them myself but they should be fine, at least for the return to home feature.
if i buy only the motherboard how will i activate my iphone with a broken home button??
@lmn_munir You'll find some hints here: Press home button to upgrade (broken home button))
Or, if you prefer watching, you'll find some youtube videos, just google: "activation without home button ios 12"
Thanks for the info
If it is the board that houses storage then yes. Usually storage is on main board with all other vital components such as processors and memory so basically yes it will be bypassed when logic board is replaced.
このアンサーは役に立ちましたか?
Sorry the answer is no. One can’t replace the logic board and expect to unlock iCloud. Besides, why do you think the logic board you are getting is clean either.
If the phone is iCloud locked then its not yours.
このアンサーは役に立ちましたか?
why won't it be bypassed all the locks and data is in storage modules and logic board would replace everything and it will be like new phone. stop telling wrong stuff he may have forgotten password or something
The Touch ID within the button is also involved here. so you would need to replace it as well. with the matched logic board.
Its just cheaper getting an unlocked phone from the get go! Than all of the hassle, risks and if you get a bad logic board having to buy still another.
It is possible to own a iCloud locked devise thy are all over eBay
The only benefit into buy one is to gain some of the still usable parts for someone who services them.
iCloud locks are a death sentence other then parts. The problem is the serial number will ID it as a iCloud locked board plus you need to do MASSIVE amounts of hrdware hacking to remove it in addition to giving it a new serial number.
@danj is right - you buy them for parts ONLY. If I needed a spare part that's made of unobtainium, I'd find an iCloud locked phone and keep it for anything else I may need in the future, since I have a whole donor device. That also applies to bad IMEI phones on the Android side - parts only.
Lol yes replacing the board would mean u have a new heart and brain to the phone so its essentially like buying a new phone whilst just using ur old screen, housing and battery
Obviously check you have the board with a matching home button and make sure the replacement board is a good working board unlocked or suitable for ur network and it's not got iCloud on it lol also bare in mind that these will most likely be repaired boards
P.s ur not bypassing activation lock ur basically replacing the actual phone with another one. So anything on ur old board will still be there like activation lock and any data u may need
このアンサーは役に立ちましたか?
I bypassed the fRp on a moto e by putting the locked main board into another phone that had everything but and somehow it bypassed the frP for me
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 704
