メインコンテンツにスキップ
このモデルは2016年に発売されました。2013年に発売されたCUH-ZCT1に変わる後継機です。コントローラーは前モデルと類似しています。
266回答 すべてを表示
Strange behavior after replacing USB port
After a while of use, my DS4 controller would not charge via the USB port. I purchased a USB port replacement, but found that the controller still would not charge, even though with the new part (as with the old part, in fact) the LED would light up for things like pairing and connecting via Bluetooth (though it would not light up orange for charging). Furthermore, the LED would only light up for the above scenarios when plugged in via USB.
Is this a battery issue? What am I missing?
I’ve used 70% isopropyl alcohol to clean some parts in the past, is it possible there is liquid damage?
Thanks very much for your help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It could absolutely be a battery issue … if you have another controller that works swap the battery as a test … if it fixes it, then buy a new battery. It would be highly unlikely that the charging circuit failed while the rest of the controller still works.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I don't have an extra controller with which I could test the battery, but I do have a multimeter. How would I use this to test this issue?
さんによる
コメントを追加
回答を追加する
choi.brandon.h さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 38
