Why is my ipad mini 4 rebooting at random
Screen goes blank then apple logo reboot
To no avail
done factory resets. Setup as new device.
Battery cycles around 400
device has latest updates as well as all app
この質問は役に立ちましたか?
To no avail
この質問は役に立ちましたか?
If you have a Mac or a friend with a Mac, download and run Coconut battery, plug your pad into the USB port and wake it up. Coconut Battery has an iOS option that will detail information about your battery
このアンサーは役に立ちましたか?
You’ve either got something shorting to ground in there, or you have a faulty thermal sensor that is causing the problem … but it is quite possibly something that is happening when the device heats up.
Try this … get a desk fan, and aim it at the ipad while you’re using it and see if the problem still happens or possibly stays running longer while its being cooled by the fan…
このアンサーは役に立ちましたか?
I think it's a bad battery.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 6
今までの合計 519
