Internal hard drive replacement
What internal hard drive is compatible with my system?
You’ll need to get a SATA II (3.0 Gb/s) compatible drive. Your options are either a HD, SSHD or SSD drive.
Depending on your current drive you may want to look at just adding a second drive in this case a SSD to give the system some zip! The easiest way is to swap out your optical drive for a special carrier and the SSD. Here’s the guide iMac Intel 27インチ EMC 2309/2374 デュアルドライブの交換 to follow and here’s the carrier iMac & Mac mini Dual Drive Enclosure
If your current HDD is failing then you could go with either a SSHD or SSD both offer better performance than a traditional HDD your system currently has. Here’s the guide to install it iMac Intel 27インチEMC 2309と2374のハードドライブの交換. You will need this in-line thermal sensor as todays drives often don’t have the needed hookups for the system to access the internal drives sensor Apple was expecting OWC In-line Digital Thermal Sensor for iMac Late 2009 - Mid 2010 HDD or SSD Upgrade
OK so far we’ve talked about the two possible mounting options, lets talk about the needed drive. As I stated at the beginning your system requires a SATA II compatible drive. You’ll want to review the spec sheet of the drive you plan to use to make sure it lists SATA II (3.0 Gb/s) support. Many of todays drives are fixed SATA III (6.0 Gb/s) which will only work in a SATA III system. Some drives offer multiple SATA I/O support (we call these drives Auto Sense).
As an example here are two drives:
You’ll note both of these list 3.0 Gb/s on the interface line.
製品
$19.99
ガイド
難易度:
中レベル
40 minutes - 2 hours
ガイド
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 49
1件のコメント
Your systems specs: iMac 27" 3.06 GHz Core 2 Duo (Late 2009)
Dan さんによる
