volume constantly increases and on/off led flickering
The volume constantly increases and the on/off led is flickering,
powered down tv but same fault occurs when tv is switched back on.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @darrendurnin ,
Try removing the batteries from the remote control unit in case it is a stuck button causing the problem.
If the remote is the problem, use the buttons on the TV to operate the TV until you fix the remote.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 72
