メインコンテンツにスキップ
The Chevrolet Silverado is a line of trucks under the Chevrolet brand and manufactured by General Motors. Mechanically, the GMC Sierra and Chevrolet Silverado are identical.
28回答 すべてを表示
Failed inspection because of emissions problem
Monitor EVAP NOT READY
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I think someone is blowing smoke up your tailpipe:
Your vehicle may pass the smog inspection with an incomplete EVAP monitor. The Bureau of Automotive Repairs has reduced the number of allowable incomplete OBD II readiness monitors for both the new BAR-OIS smog inspection system (applicable to 2000 & newer vehicles) and the BAR-97 smog inspections systems (applicable to 1999 & older vehicles), however the EVAP monitor is the one monitor that is still allowed to remain Not Ready and will not cause a smog test failure.
The new Emission Monitor Requirement criteria is as follows:
- 2000 and newer model year gasoline powered vehicles will need all emission monitors in READY or COMPLETE status, with the exception of the EVAP monitor. An incomplete evaporative monitor will not cause a smog check failure. It will be the only monitor allowed to be incomplete on a 2000 & newer gasoline powered vehicle.
https://m.smogtips.com/OnlineForumQuesti...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
T Webb さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 220
