Please note that MacOS doesn’t natively support touchscreen displays, well, at least not for the touch option. So, you would have to find a tweak that would enable this, or it wouldn’t work anyways.
Now for the actually answer after my little roast on MacOS for being not touchscreen display compatible lol.
So, for the soldered connections, there is really no space to install a slot for a stick of ram, which is how they crammed all of the power into the laptop.
The only way to upgrade the CPU is to have micro-soldering skills, and a CPU compatible with the socket and the model identifier.
For the GPU, it is soldered to the board like the CPU, and you would have to have a GPU compatible with the socket and the model identifier.
So, in conclusion, there is really no way to install a ram slot in the place of the soldered ram, and the CPU is pretty much limited to CPU’s compatible with the model identifier, e.g MacBookAir7,2, but with a Pro instead of Air.
1件のコメント
what is your question?
Dan さんによる
