メインコンテンツにスキップ
The HP Flyer Red is a laptop created by Hewlett Packard which was released around December 2014.
31回答 すべてを表示
8, I and k keys not working, replaced keyboard and same problem, help?
So a couple of weeks ago I spilled a drink onto my latop, completely soaking it in parts. The screen went black with only a few strips of colour at the bottom. I took it completely apart and dried and cleaned it out and reassembled it. Everything works perfectly now except the 8, I and K keys. Thinking it was from the water damage I ordered a new one and replaced it today but the same keys don't work. I'm worried I damaged something removing the keyboard ribbon as the clamp holding it was extremely difficult to open. If that's the case what exactly do I need to replace to fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There might be a problem with the ribbon connector on the motherboard, as you might’ve damaged that when you were pulling out the keyboard, so if you have a way to test this, I advise that you test it.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
What methods can be used to test this?
さんによる
The only real way to test this is by having a motherboard that worked from a different laptop of the same kind, which would require sautering to perform, and there might be a way to test it with a multimeter and checking the pins that those keys go to.
さんによる
The top pictures seems to show a bit of corrosion by the ribbon cable. You can try using Q-tips moistened with isopropel alcohol to gently clean the corrosion off of the small components and traces. This may help with resolving the keyboard problem.
さんによる
コメントを追加
回答を追加する
Becka Saurus さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 21
今までの合計 531
