メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
779回答 すべてを表示
Quick question about upgrading RAM and SSD
Early 2011, 13” Macbook Pro 2.3 GHz Core I5. Not so much worried about upgrading the RAM, that seems super simple, just make sure the new memory (I am going Crucial RAM) is plugged in correctly right?
I am a little more apprehensive about upgrading to an SSD, as my computer works perfectly fine as is and I would hate to break the HD SATA cable and have to go through fixing that as well and possibly having that start to fail constantly as I have read so much about online. So my question is, any way I can tell if the cable is likely to break by just removing the bottom cover of the MBP without disturbing the SATA cable? Should I just let it be? If my hard drive has failed and been replaced in the past, what are the odds I already have a newer HDD SATA cable or does that mean I am more likely to have a bad HDD SATA?
Kinda a why fix what’s not broke type of deal, I only use this laptop for browsing the web and emulating some older games so I am thinking an upgrade to the 8 GB of RAM from 4 GB would be enough (Activity Monitor tells me I am using 3.5 GB when I have 3-4+ Chrome tabs open, and about 3 GB when I am only running RetroArch). Above all I would hate to lose this machine, so give it to me straight, what is the risk I run of messing up the HDD SATA cable if I try to upgrade to a SSD and is it worth it in terms of what I use this laptop for.
Thanks in advance for any advice!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
As they say you can’t make scrambled eggs without breaking the eggs ;-} The problem is more complex than just lifting the cable out to fit the new drive in.
First the 2011 models originally had SATA II (3.0 Gb/s) HD drives. The original cable was only rated to run at SATA II specs! Now you’re putting in a SATA III (6.0 Gb/s) drive into your system. In addition to this the rough surface of the uppercase tended to wear the cable. This is why we need to replace it when you upgrade the drive to a faster drive.
So we have a double whammy here and we still haven’t dealt with the issue of the folds of the ribbon cable.
So where does that leave us? As a matter of course I replace the HD SATA cable at the same time I upgrade SSD’s in both the 13” and the 15” 2011 models. If you’re so lucky to already have the newer version of the cable as someone had already replaced the drive before then you might get away without changing it.
So I would recommend you just make the effort to replace it MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable And yes! This is not the 2011 version! The 2012 version is a better cable. But before you put it in we want to place a strip of electricians tape on the uppercase when’re the cable crosses over to help protect the cable from the rough aluminum surface. The next issue is the bends and folds. Many people think you can take a knife and bend it around the edge, this will in fact damage the cable don’t do it! We want smooth arc in the bends.
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cableの画像
製品
$34.99
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
@danj Not doubting you at all (you know much much more than I do about Mac repairs), I guess I am still confused. When I check the system specs on everymac it tells me the "storage interface" is Serial ATA (6 Gb/s) and when I click on that, I get this expanded message "This model supports a single SATA III (6 Gb/s) 2.5" hard drive or SSD that is up to 9.5 mm thick." Does this mean I have the SATA III cable already or its just the maximum I can have in the system?
My SATA system report also shows I have Intel 6 series chipset with a Link Speed of 6 GB/s and a Negotiated Link Speed of 3.0 GB/s. I was under the impression that meant it could support a 6 GB/s drive natively and the negotiated link speed was the speed the current HDD could handle.
Thanks again Dan!
さんによる
EveryMac is Correct! the system does have a SATA III (6.0 Gb/s) interface! And yes what your system is reporting is correct!
Lets get into the wayback machine!
Its now the end of 2010 you are in design review meeting at Apple, the last one before going into production. You are the person responsible for the drive subsystem and you have some bad news to share with the group. The suppliers are unwilling to commit to the quantity of drives Apple needs at the price Apple is willing to pay and the first version of the SATA ribbon cable is not going well as it's not able to run at the higher SATA III data rate. So Steve tells you lets just go with the SATA II drives and when we need to re-contract the drives we'll hit them up then for the faster drive and for now use the cables we have.
A few moths later Apple released a newer cable and turned on SATA III services within the systems firmware Apple was still was using SATA II drives (the last build of the early systems did get the SATA III drives and the late 2011 models did as well).
But, Apple still had a crappy SATA cable it wasn't until the 2012 systems came out did they get it to work flawlessly at full SATA III data rates. You see SSD's can push more data than what the older cable can support and HDD's didn't push the limit so it was possible for them to get away with using the crappy cable (gen2).
さんによる
@danj awesome thats very informative thanks Dan! So to clarify, technically yes the current cable could be connected to a SATA III drive, it just simply wouldn't push the same speeds as the newer cable and would defeat the purpose of a faster drive, is that more or less correct?
さんによる
That's a good summary. To come back to one brief issue: it's critically important NOT to crease the cable. It makes the stranded copper fibers inside of the cable crack and break; while they may remain in contact at first, eventually they will corrode and/or migrate, causing the cable to degrade and fail.
さんによる
@urbs_ - The ability of the drive and the ability of the system is limited by the cable connecting them. You will encounter CRC errors which will create corruptions on the drive and cause your system to overheat (a damaged cable will likewise cause these errors)
Yes! David, You are correct damaging the cable is a common issue! This ribbon cables are in fact foil not braided wires. Just like how a paperclip fatigues when you bend it a few times the foil conductors likewise get damaged from the creasing or when you over bend the cable.
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Andy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 57
