New battery displaying incorrect percentage & dying around 30%.
Hey all,
Just replaced my Macbook battery and the charge is lasting a fantastic amount of time! Only problem I’ve run into is an inaccurate display of charge. For instance, Coconut Battery displays it at anywhere from 95-99%, while the icon on the top bar displays 100%.
I was in the process of calibrating it after an SMC reset, but noticed that it went to sleep at around 29%. I know we’re supposed to wait at least five hours so it fully drains before charging again, so I was concerned that it wouldn’t be enough time if it was still so high.
Any advice on this? Here are specs on the battery:
System Info:
Battery Information:
Model Information:
- Serial Number: D8622873BQZDNMGAX
- Manufacturer: SMP
- Device Name: bq20z451
- Pack Lot Code: 0
- PCB Lot Code: 0
- Firmware Version: 511
- Hardware Revision: 3
- Cell Revision: 1150
Charge Information:
- Charge Remaining (mAh): 8071
- Fully Charged: No
- Charging: No
- Full Charge Capacity (mAh): 8604
- Health Information:
- Cycle Count: 2
- Condition: Normal
- Battery Installed: Yes
- Amperage (mA): -1670
- Voltage (mV): 12058
P.S.: Other small issue, Dark Mode keeps switching off and back to Light Mode after shutting down and restarting. Mildly irritating.
この質問は役に立ちましたか?
1件のコメント
You'll need to talk with the seller of the battery to get a replacement battery.
Dan さんによる
