メインコンテンツにスキップ
1.86GHzもしくは2.13GHzプロセッサ、フラッシュストーレッジは128GB もしくは256GB
147回答 すべてを表示
want to confirm that replacing the logic board will solve my problem
I have a 13” late 2010 MBA. It was giving me some trouble, so I took into a local certified Apple service center (I live in central Mexico). Two things were identified as “fail” during their diagnostic tests. (1) Full System Diagnostic (OS) - exhibiting problems with the SSD (Drive Block Read), and (2) Full System Diagnostic (EFI) - faults during tests of the memory and SSD. They said they don’t have a source for a new logic board for my computer since it is so old.
I am assuming that I could solve these problems myself by replacing the logic board with one purchased through iFixit and replacing the SSD with one from either iFixit or OWC. Am I correct?
Also, I’m not sure which processor I currently have. The only logic board currently available for my computer through iFixit is the 1.86GHz model. Does it matter which processor I choose?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Yes, those should solve your issues.
Are you sure their tests indicated a problem with the memory (RAM) specifically though? If it was only the SSD you wouldn’t need a logic board replacement.
Processor speed affects just that, the speed of the processor. I would say you’re probably fine with the one iFixit sells but it depends on your workload.
Honestly however, I probably wouldn’t go through with the repair, personally. ~$300 for a logic board and SSD is a lot to drop on a 2010 MBA, when you could get a 2012+ MBA for $300-$400 that will work with the latest software updates (Mojave), etc… The 2010 is pretty near its end of life in general.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thanks, Jonah, for your response! I'm exploring options to keep this old computer going. I don't use it for much anymore. The logic board would be $175US from iFixit, and I could get a small, 64GB SSD for $60US. Cheaper than a replacement computer.
さんによる
There's actually a lot of options on eBay, etc for a 2012 around $250 it looks like, which is only what, $15 more? But if you're in some other country or that isn't feasible for some other reason, then yes, you should be good to replace those components :) I just generally hate to recommend repairs on the more expensive side like this, on pre-2012 MacBooks as a rule.
さんによる
Your point is well taken. Like I said, I'm just exploring options. Thanks for your input!
さんによる
コメントを追加
回答を追加する
Mark Wirganowicz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 57
