メインコンテンツにスキップ
Repair and troubleshooting guides for air conditioning units used in houses, offices, and cars.
34回答 すべてを表示
My air condition is not working properly.
I found out that whenever I put on my air conditioner ( AC) the compressor works for some time and then stops then after some minutes it would start up again and repeat the same thing.
Please I need your help. Tell me what to do,
Thank You
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
@shiyanbolat
what make and model is your AC? while it runs it does cool? How long does it run? You checked the thermostat and the settings?
さんによる
コメントを追加
3件の回答
Either the compressor has failed and/or the coolant has leaked out.
Best to bring your AC unit to someone who has the proper tools to properly diagnose whats failed here and see if its repairable.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
there are multiple possible causes for this. I would recommend calling a tech out.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I agree entirely; in such breakdowns, it is better to consult a specialist. There are many air conditioner maintenance services like https://www.socool.sg/pricing/ on the market. They will help you save time, money, and nerves. Somehow I tried to fix the vacuum cleaner, and in the end, I broke it down to a complete malfunction. Therefore, it is better not to experiment with appliances in your home. The repair will always cost you less than buying a new one in case of failure from self-repair. In any case, this is not a simple gadget. This is the air you breathe.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Shiyanbola tunji さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 104
