メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
The Xiaomi Mi A2 (Also known globally as the Mi 6X) was released by Xiaomi in July 2018 in various internal memory configurations. It is part of the Android One program which guarantees updates for two years.
30の回答 すべてを表示
Phone is not turning on. It just vibrating when I used to turn on. Bu
My phone got switched off. And now its not turning on. When I used to turn it on, its just vibrating and showing white display with android one. But not turning on. What should I do....
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメント:
My mi a2 is a year old and the display keeps turning on and off. Even so I get to feel vibrations when I press the power button or when messages come in. The mobile rings as well when I dial my number from another mobile. Planning to take it to a sevice centre.
さんによる
コメントを追加
The Essential Toolkit
コンパクト版iFixitキットの中で最も利便性の高いツール
ショップを見る
ショップを見る
1 件の回答
You can try if the “recovery“ works.
  1. Hold Power & Volume Up until the screen shuts off
  2. Release both buttons and immediately press and hold them again
  3. Retry until you can see the “No command“ screen
  4. Just press them both a the same time once and for the least
There should be some options to choose from with:
  • Volume UP/DOWN
  • POWER to select
From here you can try to factory reset the phone which erases all user-data but can get rid of many problems…
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
yogeswarireddy さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 251
