Putting an iPhone 7 battery to an iPhone 6s
So this is regarding interswapping battery between units, answers says it works and people are actually confirsming this, the catch is you have to bend the flex cable slightly for shape…
That does seem to be correct, you should be able to use an iPhone 7 battery in a 6S model for higher capacity.
このアンサーは役に立ちましたか?
I have just looked at both batteries. They seem to both have the same connectors and the iPhone 7 battery is higher capacity, but strangely smaller than the iPhone 6s, so I think you could probably install the iPhone 7 battery in to the iPhone 6s, but probably not visa versa due to size constraints.
このアンサーは役に立ちましたか?
I have just read on on another question that this is 100% possible… iPhone 7 battery into an iPhone 6S.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 683
