メインコンテンツにスキップ
モデル番号はA1040/10、15、20、30もしくは40GBハードドライブ/タッチホイールの上に4つの感知式LEDバックライトボタン
Battery Replaced, Recognized by Computer, Won't Charge?
I just replaced the battery with an iFixit (super easy!) and the iPod started right up. It is showing little to no battery power. When I connect it to by Macbook, iTunes recognizes it, but it does not charge. I’ve tried multiple chargers with the 30-pin cable (brand new) and I can’t get the lightning bolt to come up.
The only suggestions I’ve seen are related to replacing the battery, which is what I just did. I went back, disconnected the (new) battery and reinstalled it, still the same issue.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
It’s FireWire…isn’t it? I’m not using FireWire to charge…
さんによる
To clarify, when you said, "The only suggestions I’ve seen are related to replacing the battery, which is what I just did. I went back, disconnected the (new) battery and reinstalled it, still the same issue." does this mean that you disconnected and reconnected the NEW battery, or you disconnected the new battery and reconnected the OLD battery? I'm curious to see if the iPod will charge on the old battery.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Your problem is the connection. The iPod 3rd Gen does not charge through USB but needs Firewire connection. This model only syncs through USB. Hope this helps, good luck.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
You need a FireWire cable and power adapter to charge it.
Cable: https://www.ebay.com/sch/i.html?_from=R4...
Power adapter: https://www.ebay.com/sch/i.html?_from=R4...
Note: Some eBay listings already include both things in them, since they are used together.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ryan Harris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 114
