メインコンテンツにスキップ
2.0GHz, 2.3GHzもしくは2.6GHzクアッドコアIntel Core i7プロセッサ (Turbo Boost 最大3.8GHz) 6MB共有L3 キャッシュ付き。
580回答 すべてを表示
MacBook's display neck is disoriented
So, I have this MacBook who’s display neck is disoriented and it no longer overlaps with the keyboard area while closing the lid as it should normally do. The display is fine and everything works fine but I’m just concerned about closing and reopening the lid everytime.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Can you please verify if your hinges is loose?
さんによる
コメントを追加
3件の回答
ベストアンサー
You will find 6 screws holding the screen to topcase once you remove the bottom cover. All you have to do is to loosen them a bit, correctly position the screen and tighten them again in the right position. You can get a help figuring out what to do in detail with the following guide:
MacBook Pro 15" Retina Display Late 2013のディスプレイアセンブリの交換
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
If your hinges is loose you can tighten them. just wath the link
https://www.youtube.com/watch?v=vLSd_UA-...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Could be the display cable.
このアンサーは役に立ちましたか?
スコア -2
6 件のコメント:
The most easy way to test your issue is to connect the mac to a external display and try to reproduce the issue.If you don’t see the issue in the external display is the cable because a loose hinge is related to loose display but if you see flickering when you move the screen could be the cable.Try with a external display
さんによる
@gadgetboxrd - Sometimes you need to read the question a few times to figure out what it is.
Mohit's issue is the display lids hinges.
Lets re-read what he stated: "display neck (hinges) is disoriented and it (the display) no longer overlaps with the keyboard area while closing the lid as it should normally do. The display is fine and everything works fine"
So the display's image is working just fine!
さんによる
Connect to external display....learn @dan is free.
さんによる
@danj was just trying to kindly draw your attention to the fact you didn't understand the question but it seems the matter is beyond any hope.
さんによる
@arbaman - I guess a square peg can fit a round hole! ;-}
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Mohit Shah さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 80
