メインコンテンツにスキップ
2017年10月31日に発売された「Amazon Echo 第2世代」。高さ5.8インチのBluetoothスマートスピーカーで、クラウドベースの音声サービス「Alexa」を搭載し、質問に答えたり音楽を再生したりすることができます。
5回答 すべてを表示
Temperature reading is 4 to 5 degrees low
Is there a way to adjust the temperature reading on my Echo 2nd Generation Plus.
It reads about 5 degrees low all the time. Can this be tweaked inside, or do I have to mentally add the 4 - 5 degrees when I look at room temp ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
選択されたソリューション
I haven’t found a way - I get the same response, a AC unit nearby is always about 3-7 degrees higher. I’m going to guess the sensor is ‘calibrated’ at the factory and the Echo just reads the results. Besides soldering & replacing the sensor to hopefully fix the temperature setting, I’d call Amazon, I had an excellent experience with their customer support. You other option is to replace the board itself, maybe trading in your broken board to help lower the price of a new one. There’s a take apart here on ifixit on how to replace the subwoofer; You could use those instructions to take the boards out & replace the one you want. That’s another question; Where is the temperature sensor!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Are you talking room temperature? Or outside, outdoor temp?
For room the echo plus 2nd gen has a temp sensor built in, for outside temp it uses a weather service such as weather channel.com
さんによる
コメントを追加
its pulling the weather data from a data provider, as far as I know there is no way to change this at the moment.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Not the echo plus 2nd gen it pulls outside temp from a weather service, however temp in its surrounding s aka room is from q on board sensor just ask what's the temperature in this room , unlike other echo products echo plus 2nd geb xan give you that! :)
さんによる
コメントを追加
Echo plus 2nd gen has a onboarding temp probe, for room temp, pulls data from a service like every other echo for outdoor
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Glen Roof さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 34
今までの合計 2,081
