I have installed a new black ink cartage, not printing, color is fine
HP OfficeJet Pro 6960 is not printing in black ink
If you see an “0x6100004a” error, your printer must be serviced. Otherwise, you may have a bad cartridge.
このアンサーは役に立ちましたか?
If it’s been a while since something was printed, it could very well be that the head is clogged. I had that problem with my printer recently. You can probably find a tutorial online on how to clean it with some acetone.
このアンサーは役に立ちましたか?
Try setting print options to gray scale and print a test job. If you still do not see anything then you may have a defective ink cartridge or the print head needs to be cleaned or replaced.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 679
