メインコンテンツにスキップ
TI-84 Plus calculator support.
37回答 すべてを表示
My screen is hard to see when looking straight at it
If I am in a lit room I can’t read my screen when looking straight at it. I have to look at it from an angle. It looks like there is a dark circle covering the screen but it’s not there when the screen is off
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
There could possibly be a problem with the LCD in the device, depending on use and time that you’ve used it, or possibly just the battery needs to be replaced which could very well be causing the problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Adding onto what TheYootx Media Group said, another possible issue is the contrast was turned down too far. You can easily fix this by (make sure the calculator is turned on) repeatedly pressing [2nd] then the up arrow until you can see the display again. If this doesn’t work then it’s either a battery issue or a display issue. If there’s a display issue, then this article may help you repair it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mary Ringgenberg さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 11
今までの合計 234
