メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPhone 4のCDMA版モデルです。修理はそのままパーツに作業をしますが、フロントガラスとLCDはユニットで交換しなければなりません。16もしくは32 GB / Model A1349。
Are the Verizon and AT&T iPhone 4 Batteries the Same?
I know that some of the hardware is different for the Verizon and AT&T iPhone 4s, but do I need to find a battery made specifically for the Verizon iPhone 4?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
ベストアンサー
We think the batteries will work in both phones. There are different apple part numbers (APN) for the batteries but that is common for iPhones even within the same device. We've tested all possible combinations of APNs and iPhones and have not had an issue. We have just listed the part we sell as compatible both for the AT&T(GSM) and Verizon(CDMA) iPhones. Check it out here.
We took a sample of 5 iPhones we have around the office that were purchased at different times. 4 were AT&T and 1 was Verizon. 3 of the AT&T batteries had an APN of 616-0513. 1 AT&T and the Verizon iPhone had a battery with an APN of 616-0520. That means that Apple was using the APN 616-0520 for both models. It was also the official white iPhone that had the 616-0520 battery which came out around the same time as the Verizon iPhone. The batteries we sell carry a part number of 616-0521 which works fine in both iPhones in our own internal testing.
We will keep an eye on customer feedback just to make sure that we don't run into issues but at this point we think the batteries are cross-compatible.
Replace a 1420 mAh battery compatible with all iPhone 4 GSM and CDMA models (Not 4S), and does not require soldering. 3.7 Volts (V), 5.25 Watt Hours (Wh).の画像
製品
iPhone 4 Battery
$11.99
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Yes.
製品
iPhone 4 Battery
$11.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Cecilia Ossenbeck さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 13
今までの合計 10,290
