How to remove jpeg compression on my phone
how to remove jpeg compression on my phone:
SonyEricsson Cedar j108i
n how to improve internal speaker volume(quality)?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The way I read the instruction on the forum that you posted, first you download the file " camdriver0.rar" Remember that you will have to register before you try to download that file. Then you use software called "farmanager" which is available here. After that, you will need the sefp2 plugin which is available here with instructions.
このアンサーは役に立ちましたか?
....thakU :)
you are welcome ;-)
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,001
2 件のコメント
karty, I am a bit at a loss. The link you attached tells you where to download the modified driver, and it tells you have to install it. So what exactly can we do for you with that?
oldturkey03 さんによる
thkz can u plz tell me the procedure? ?
i dnt getn wat dey rwr sayn :(
karty さんによる
