What is the display connector part on a late-2015 iMac?
I have a late-2015 iMac 5k with a broken display. It looks like the previous owner broke a couple pins on the logic board connector based on the couple missing pins on the original LVDS cable. Even when I connect a working display using a new cable it doesn’t function.
It’s not the display or the cable as I’ve tried both on another iMac 5K.
I’ve seen this (the logic board connector) referred to as a LVDS or a special eDP connector.
*Where can I buy this? And can I find someone to solder/replace it for me?
I’ve also tried reseating the cables with no luck. Is there something else I could try?
It’s one of the i7 models with m395x. I’d hate to junk it.
この質問は役に立ちましたか?
6 件のコメント
@dieselm if you can give you your Mac Model No. or SN I can link you to the replacement Logic Board.
Alex Robinson さんによる
I'm going to take a wild guess and say its an A1419 "Core i7" 4.0 27-Inch. If this is the case, here's the part:
iMac Intel 27" EMC 2806 Logic Board
Alex Robinson さんによる
I'd rather not replace the whole logic board. Can anyone identify the connector part on the logic board?
Diesel mcfadden さんによる
Don't guess! Look on the bottom of the stand, get the serial number, plug it in here and tell us EXACTY what machine you have. We can then better advise you.
https://everymac.com/ultimate-mac-lookup...
mayer さんによる
emc 2834, a1419. iMac 17,1
1以上のコメントを表示
