メインコンテンツにスキップ
基板とCPUのための修理ガイド
165回答 すべてを表示
My front USB ports do not work
I own a Corsair 460x and a Z270. One of my front USB slots gives out power but does not recognize some devices while the other one does not work at all. I faintly remember it working when I first made the PC. I have uninstalled the drivers but there is no change.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hey Alex! It sounds like either an issue with the motherboard, or an issue with your operating system. I’d say it’s likely the motherboard headers. Since you built this PC, I imagine you know your way around it, so I’ll give you a straight answer here. Try taking the side panel off and messing with the USB headers, maybe blow out the connectors, or try reseating it at the very least. Also, do your front panel audio jacks work? If it’s a motherboard issue, they’d likely have some sort of issues. Good luck!
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hey I'm going to try do that. Also the Front audio jack also does not work. Thanks for the help :)
さんによる
コメントを追加
回答を追加する
Alex Anderer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,883
