メインコンテンツにスキップ
Released in 2013, the Model #412540 is a Wifi connected portable music device using Android or Apple devices downloaded with the SoundTouch app.
SoundTouch Portable won't turn on. New battery.
I recently purchased a non-working SoundTouch portable. The seller thought it was just the battery, but that does not seem to be the case.
I have tried hard resets but am not having any luck.
Bose Support has stated they can fix it for me for $99 if I send it to them. I’d like to see if there are things I can do before sending.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
I’m looking for a way to eliminate the battery, as I can do without the portability.
When I take out the battery, the unit will still not boot.
Does anyone have a schematic of the unit, so I can bypass the battery and just use it on the dongle AC power?
さんによる
I ended up sending it to Bose to have them fix it.
I did check continuity and some other things, it seems that my issue was a blown board.
さんによる
コメントを追加
3件の回答
Hey Joseph,
Seems that I have a very similar problem as yours.
Unit does not show any signs of life.
I replaced 2 caps on power pcb that were slightly expanded. Still no life.
When I measure volts on batery terminals on a speaker side, I get 18V. However when the battery is connected, the most I get is 8V.
11V battery can’t get charged with 8V. And batt is dead completely. Nothing on any terminal.
Have you figured it out if unit can be operated on AC power without a battery?
Thx
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same seem to have happened to my unit after I was forced to upgrade to the latest firmware.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If the battery is not charging (and app. stops working because empty battery) then a condensor of 10uf/35V is defective (to high ESR). Naer the coil.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Dear Edzard,
can you please describe a bit more detailed what capacitor you mean?
I do not understand "Near the coil", what coil you mean.
さんによる
コメントを追加
回答を追加する
kyhokie さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 19
今までの合計 1,422
