メインコンテンツにスキップ
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
My calculator doesn't turn on anymore
My calculator stopped working out of no where. It doesn’t turn on no matter what I do. When i plug it in the orange light indicates it is charging. It will turn green after a while indicating it is fully charged. But when i plug it out and plug it in immidiatly after it goes through the same process again. It just doesn’s seem to charge. Does anyone know if there is a fix for this problem?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Edit: It also doesn't get rocognised in the TI connect software when i plug it in to my pc.
さんによる
I have this problem too. But the first thing that happened was that I fried the transistor that controls the LED, which I soldered off. But now after 3/4 months of giving it life support the thing doesn't want to turn on or charge anymore.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi, thanks for including all that information! I think TI-84 Plus CE Recovery Techniques. is what you’re looking for. Please comment if you still can’t get it working and I’ll keep trying to help!
P.S. The charging light is separate from the main calculator software so it can still charge even when the main calculator is frozen or broken.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
sorry for the late reaction but i did all of the above but it still doesnt work
さんによる
Well that's surprising, even trying the OS reinstall didn't work? Were you able to get the display to even turn on for a second? This may be a display issue. I know you said you tried this before, but since you did some of those recovery techniques, something may have changed. If you plug your calculator into your computer, does your computer recognize that something was connected? If so, then it's most likely your display that's broken. Let me know if you think that's your problem. If your computer doesn't recognize that something was connected, then you've got hardware damage. You can try to take it apart by using a teardown guide ( TI-84 Plus CE Teardown ) however if your calculator is still under warranty, I would highly suggest turning to TI customer support and requesting a new calculator instead: https://education.ti.com/en/customer-sup...
さんによる
コメントを追加
回答を追加する
Martijn Wobbes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 19
今までの合計 1,078
