failure to print,copy or fax
My 6600 has stopped printing and a notice that it will not print copy or fax appreared
I had the same issue mine sap out of use for about 4 months so the needle that injects the ink dried up on the end of the tip and I had to pull it apart and take some rubbing alcohol and clean the tip of the needle try that once but be careful to unplugged copier printer first I hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 302
