メインコンテンツにスキップ
JBL Charge 4は、スマートフォン用のポータブル充電器としても機能する、Bluetooth対応の防水スピーカーです。 モデル番号で識別できます: CHARGE4S.
36回答 すべてを表示
JBL Charge 4 speaker suddenly stops playing sound
My JBL Charge 4 bluetooth speaker was working fine until it suddenly stopped playing sound (even the ones it plays when it turns on, off, etc.). I don’t know what could’ve caused this since I don’t use the speaker on max volume. Speaker was charged and it connects fine, hasn’t gotten extremely wet either.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメント:
Jbl started having severe noise distortion and all of a sudden just stopped playing or making sounds at all. No power up or power down sound even though it seems to be connected to my phone. It is fully charged and brand new. Any advice?
さんによる
Same problem with mine, though no noise distortion before it fell silent suddenly. It was playing normally, then suddenly nothing. No power up or power down sounds, no connect sounds though it is connecting. Nothing. Pretty much still new. What’s the problem here?
さんによる
For the charge 4, the reset buttons changed to the play/pause button and the bluetooth button
さんによる
anyone got a solution for this? my Charge 4 just stopped producing any sound for no absolute reason, even the on/off sound is not played now, it connects normally but totally silent. factory reset didn't solve it. any help?
さんによる
Same for me - brand new and stopped producing sound out of nowhere - what a crap
さんによる
5件以上のコメントを表示
コメントを追加
7件の回答
最も参考になった回答
Try powering on yourJBL Charge 4 first and wait for the LED indicator to turn on. Then try holding down the play/pause button and the volume up button up to 20 seconds and that should factory reset your device. Then try again and see if it makes sound.
I personally have a JBL Xtreme and I’ve had similar problem and factory reset fixed mine. Hopefully it works for you too.
このアンサーは役に立ちましたか?
スコア 1
コメント:
Tired that it didn't work for my charge 4
さんによる
Same problem, tried factory reset but still no sound. I need help
さんによる
Same for me, no sound....
さんによる
GREAT now my JBL won’t even turn on after doing those steps!
さんによる
Ok so this is the wrong combination for the Charge 4, mine also didn't reset and stopped turning on. I've finally found that to fix it again, you have to plug it in so the power lights up. Then hold Bluetooth and play buttons until it switches off. Then you can unplug and switch on as normal. That was an hour of stress I didn't need
さんによる
1以上のコメントを表示
コメントを追加
Mine started working somehow, i pressed both the power and connect+ button together. While keeping these pressed, press the play and volume up. I somehow got mine back to life.
Try this again and again after putting into charge and removing it from charging.
このアンサーは役に立ちましたか?
スコア 0
コメント:
Download the JBL Connect app. Pair the speaker with your phone. Select upgrade speaker.
さんによる
コメントを追加
Download JBL Connect app. Pair Bluetooth speaker. Select Upgrade speaker.
このアンサーは役に立ちましたか?
スコア 0
コメント:
Worked like a charm although I don't understand how and why I was able to to upgrade my speaker off of my phone.....
さんによる
コメントを追加
mine did the same thing after falling. I took it apart and found the part the red arrow is pointing at was dislodged. I pushed it back in and it started working again but only when I’m pushing down on it. Not sure how to keep the downward pressure with glue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had this problem and in my case solution was surprisingly stupid. Apparently I was connected to speaker on 2 devices. On pc, which was the music source, and on phone, which I used to browse reddit. Eventually I was stumbling on videos on reddit, and even without sound when you start looking at them, speaker stops playing sound on pc. So basically try checking for when exactly music stops and if it’s somehow related to what you are doing at the moment.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My JBL charge 4 was playing music then all of a sudden it stopped playing it won't turn on but when I plug it in the power button light turns on but don't do nothing I tried pressing the power button plus volume up button and nothing
このアンサーは役に立ちましたか?
スコア 0
コメント:
Did you ever get the audio working on your charge4? Mine has no audio also.
さんによる
コメントを追加
Yes is not up to a month
このアンサーは役に立ちましたか?
スコア 0
コメント:
Yes and is not up to a month what do you think
さんによる
I did the reset thing
さんによる
コメントを追加
回答を追加する
SpeakerDude さん、ありがとうございました!
統計データを表示:
過去 24時間: 45
過去 7 日: 213
過去 30 日: 1,063
今までの合計 31,750
