メインコンテンツにスキップ
The HP 15 laptop can be identified by the model number R263DX.
6回答 すべてを表示
How can rid of a black spot on my pc?
Yesterday, i got a little black spot on my pc screen. I don't know why.
And this morning i found out that is getting bigger.
Is there any solution to fix it without the need to replace it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Occasionally, the pixels on your computer screen will get stuck and you may see a red, blue, green, white or black spot. If you have a LCD computer screen, try to remove the broken pixel by lightly rubbing on it. Otherwise, use a software application to help you to remove it. Software such as Jscreen Fix, Pixel Fixer and Dead Pixel Buddy are designed to locate and fix broken pixels on a your computer screen.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Actually, i tried Jscreen Fix for about an hour. And nothing special.
さんによる
Hi @dhia1 ,
Just to eliminate the remote possibility that it is not a screen problem, try connecting the laptop to an external monitor and check if its' display is OK
さんによる
@jayeff Ok i will try it later.
さんによる
コメントを追加
回答を追加する
Dhia eddine さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 26
今までの合計 4,765
