メインコンテンツにスキップ
モデル番号はA1366/8もしくは16GB容量
174回答 すべてを表示
締切られた回答
Problems with the digitizer, and possibly logic board
Hey guys, found the site and I love it.
So I just got home from college and had my ipod in my pocket. My beloved mother wanted to do the laundry and I forgot to take it out of my pants. Unfortunately it went through the wash. I set it in rice and a day later it was fine.
I realized that night, however, that the battery no longer worked. I set apart tearing it down using a hair dryer and the tiniest edge of a razor blade to remove the screen (as carefully as possible). After removing the screws I doused the logic board in alcohol. After leaving it in for a few hours I let it dry for a day and plugged it in and viola! it worked!
Now my mom unfortunatley washed the bowl that the screws were in (minor frustration) but I set at it again for a test run without the screws. It was a little loose but turned on. Unfortunately I did not receive a response from the touch. I ran the diagnostic when it was (kind of) put together. I received an OK! in all categories except "OC" (it said C5).
I don't believe I damaged it.
Any ideas as to what I should do next. I cleaned the connectors in isopropyl and its drying now.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Dlem, I believe you need one of the screws to be grounded to the case. But I might be wrong about that. But since the nano had a wash I would say try replacing the digitizer/LCD.
But if you don't want to throw money into it, just part it out you might recover half of the money back.
Hope that helps. Good luck with that.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 991
