メインコンテンツにスキップ
Repair guides for the Kenmore 80 Series of washing machines, manufactured by Kenmore.
122回答 すべてを表示
Why does washer not spin water out very well
Why does my washer not spin water out very well
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It sounds like it is still spinning?
If it is spinning take a look for a clog in the drain hose. if nothing there follow the drain up, and look for other debris.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
worter burnette さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 298
