メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
Why is my iPhone SE turning on/off after a battery replacement?
Update: After opening up the iPhone. Reconnecting the logic board/battery I was able to get the iPhone to turn back on. I'll use Activator to lock my phone for now. I'm going to replace the Lock Button cable later to see if it will fix the issue.
Hi, so I recently replaced my iPhone battery with a new one. And my phone worked fine after a couple of days. But today my Lock Button stopped working. I’m jailbroken and one of my tweaks asks for my fingerprint every time I try to turn off the device and the prompt kept coming up even though I never tried to turn off my phone.
So I rebooted the iPhone and now its turning on/off non-stop. (Apple logo appears then shuts off and then reappears)
Any solution?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Jailbroken iphones are sometimes a timebomb specially if you have lots of tweaks.
If you tried the home and power button to restart it and its doing the same, you will have to put the phone in DFU mode and restore it with itunes, sometimes doing a restore with a jailbroken iphone give errors
Keep in mind that restoring the phone will lose jailbreak.
If you have the shsh of previous versions you can do a custom firmware and restore that to keep jailbreak
Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
TwoJayCee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 71
