My iPhone won't turn on
My iPhone won't turn on it just shows it's charging for a few minutes then the Apple log comes on and then chargin again and won't turn on.
Hello, sorry to hear about your phone. Please attempt the following:
https://help.ifixit.com/article/108-dfu-...
PLEASE NOTE that this procedure will erase all the data on your device if it works. In case you aren’t able to perform this process, or if it fails midway, you will likely need to replace the device, as this would be a motherboard issue.
Good luck!
このアンサーは役に立ちましたか?
I've tried everything and won't work
Then there you have it. Take it to the Genius Bar or to an Authorized Apple Service Provider.
Or attempt a motherboard replacement.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,095
