メインコンテンツにスキップ
My tv won’t turn/power on after being unplugged for a couple of hours
I moved my tv and then moved it back to put it back on and plugged the tv back in, no lights or anything came on when I plugged in back in. I have changed the fuse in the plug, the power cable and the socket.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
I had the same problem with our sony. later on we found out that it was a burned out screen bulb in the tv. We took ours for a tv trade in to get money off our new tv.
さんによる
Hi @k12 ,
What is the model number of the TV?
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hello,
If you had been check a all things means cable and power supply then you should talk to your customer service and talk to where you purchased it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
get it checked from some professional technician or if your product is under warranty, take it to the service center maybe some internal problem is causing this issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kier さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 854
