メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2265回答 すべてを表示
Screen won't close tight after display replacement
I replaced new display for iPhone 7 by LCD Screen and Digitizer Full Assembly Fix Kit and I have no problem during repairing steps where I applied new display adhesive.
Now I have problem when I close device that is a gap between the display and rear case, exactly on bottom right corne and on half bottom of right side.
What do yo suggest me ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
ベストアンサー
I found out problem! It’s problem with new display, I tried to assembly again the old display and It closes tight.
There is IC cent to display flat and It’s not aligned, infact bump into metal shield of rear case.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Hi
Perhaps your phone frame is bent, because of this skew the screen does not sit tight to the frame
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I have the same problem for mine, and I think it might be that the battery bracket may be pushing up on the screen. My battery bracket was popping up on one side while the other was screwed down and I had trouble screwing both of the the tiny screws in without one popping out. This causes the entire battery bracket to sit at and upward angle and apply pressure on to my screen. This may not be your exact problem but it is worth a try to see if that could be it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
it will be the small rectangular heatshield on the back of the new screen not alignet correctly, there is a recess on the loud speaker it has to sit in.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
strange thing is the old lcd sits down correctly, what do you think? It's design flaw?
さんによる
コメントを追加
I tried everything on mine and it ended up being that the back was slightly bent. I bent it back into shape gently and resolved the issue.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
omg i had the exact problem and thank you i wouldnt think the frame would be bent now i know the actual reason
さんによる
コメントを追加
回答を追加する
Riccardo さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 14
今までの合計 2,014
