2.5 SSD or 3.5 SSD?
I want to upgrade my internal hard drive of my 17" Intel iMac 2006, but I don't know if I should go with a 2.5 or 3.5?
Will a 2.5 SSD fit?
この質問は役に立ちましたか?
Will a 2.5 SSD fit?
この質問は役に立ちましたか?
With a little "McGyver" you can fit a 2,5" SATA disk or SSD. The 3,5" to 2,5" reduction frames hold the HD smack in the middle of the frame. Normally the cabels are too short, then. But you could build your own frame or even use double sided tape. I'm doing this job to my own iMac tonight, because the 3,5" drive fittet now is too noisy.
このアンサーは役に立ちましたか?
That's what this is made for: http://eshop.macsales.com/owcpages/multi...
I used a Newer Tech AdaptaDrive 3.5"–2.5" adapter to mount a 2.5" SSD in my early 2008 iMac. It worked flawlessly.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 3,255
