The tub moves a litte bit then stops, moves then stops? then
the tub moves a bit then stops, moves, then stops, how do I get to the drum to see if anything is stopping this
The drum belt is the connection between the motor and the drum, which operates throughout the complete wash cycle. It is fitted onto the motor and the pulley which turns the drum, without the belt the machine will not turn. Over time it is quite common for the belt to snap or stretch due to wear and tear.
Here’s a video on how to replace it:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 18
