Broken LCD connector on logic board
Ok. So I did a really stupid thing and thought the connectors were like iPhones and pry’d the lcd connector off logic board. Do I need to buy another logic board or is this an easy fix?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Fixing that would definitely require microsoldering. I’m not a soldering expert, so I can’t really say whether or not there’s damage to the solder pads themselves which would cause a bigger issue repairing them, but even best-case only the connector needs to be replaced, that’ll still typically cost you $90-$150 or so from a microsoldering company. Honestly it definitely isn’t an easy fix and it’s probably more cost effective to just buy a used iPad 4 from some marketplace and replace it entirely.
iFixit does sell used logic boards but it doesn’t make too much sense to me when you can buy the entire unit used for $100-$130.
このアンサーは役に立ちましたか?
Thank you @jonaharagon
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 28
