メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
Battery Replaced - MBP won't start, now with three beeps
Hi All,
As the title says - I purchased an iFixit battery replacement, as well as a new mag-safe port on my 2012 MBP Retina. The computer previously worked without issue.
During the replacement process my right speaker connector pulled off the from the logic board with very little force; besides that there were no issues and everything uninstalled and reinstalled without issue.
Now when I go to power on my laptop I get three slow beeps, a pause, and it repeats. There is no screen activity. I took to bottom cover off and the two fans are spinning slowly so I know it’s getting power. I’ve tried the power reset without success.
I’ve obviously either broken something or reinstalled something incorrectly; however, I don’t know where to begin to diagnose the issue.
Thanks for any help you can provide!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hello! The three beeps likely signify a RAM issue. On your model Mac, the RAM is soldered the logic board. So, I would start by performing an NVRAM reset (Command-Option-P-R) and see if this fixes the issue.
If not, its possible you will need to replace the logic board on your machine. Ensure that everything is properly seated, attempt to reset the NVRAM, and take it from there.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Some labs may replace the RAM chips, but on a 2012 board may not be cost efficient, it's really a tedius and time consuming job..
さんによる
コメントを追加
回答を追加する
Ben Gundlach さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 44
