I'm Having audio issues
The audio in the right side is lower than the left
Hello, from what it sounds like, I believe your earphones are dirty with earwax and dirt. What I can recommend is taking an extra toothbrush you have and wetting it with a VERY SMALL amount of water (excess could damage them) and scrubbing the earpiece that the speaker is in (circled below) lightly with the wetted toothbrush. You could also use a toothpick and lightly scrape out any dirt or earwax. Be careful and hope this helps!
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 14
今までの合計 182
