Why is my battery not charging?
Intro
So after my Original Apple Battery with around 700 Cycles was allready very bad I came to the conclusion to change my Battery.
Replacement Description
Ordered a battery on Amazon for 55€ replaced it (tough i didn’t reset the SMC, as i didn’t know what it was for).
All in all I didnt’t have any problems when replacing, had gloves on, didn’t use any metal - handled everything with love.
After Replacement
It worked for more than one week without Problems, the Capacity was really good it felt again like new to be honest. It charged up to 100%, i also got it once down to 30% but didn’t want to go any further
Problem description
After not using my Macbook for one day i came to the idea to turn it on Today. Guess what? It didn’t want to turn on —> I tought battery is at 0% or so.
Connected magSafe and startet using it —> After a Period i accidentally plugged the magSafe out of the power socket —> Macbook turns off.
I realized something was wrong and it started to feel strange :(
What i tried so far
• Tried to reset SMC several times. The magSafe LED changes (when i release the SMC-Reset combination From orange —> Green)
• Could turn on Macbook without a connected magSafe —> After abt. 5 Minutes Macbook turns off
• Opened Macbook —> Disconnected and reconnected BATTERY from Logicboad (With gloves on and no Metals have been used only plastic spudgers)
•Still the same. Didn’t work
• Tried to reset NPRAM or NVRAM (idk what’s it called)
• Tried to release SMC without a Battery attached (Didn’t function macbook instead turned on)
—> At all time, when the macbook was turned on an magSafe connected, the color of the magSafe LED is ORANGE (i don’t know if this info will help but im writing everything i know and did so far)
—> Coconut battery says that battery had no failures and is NOT being charged @0Watts @28.5Celsius ( around 85 Fahrenheit)
Now my macbook is under the bed with the Logicboard being DISCONNECTED from Battery and NO magSafe connected … :(
Take a snapshot of the main window of CoconutBattery and paste it here for us to see iFixitでの質問に画像を追加する方法
Dan さんによる
Current charge 4686 mAh
Maximum charge 8420 mAh
Design capacity: 8600 mAH thats around 97% of What it should be
Loadcycles: 1
Days old: 300
Battery temperatur 28 Celsius (85Fahrenheit)
Battery status: good
Charging with 0.0 Watts
Battery status not charging
Nenadbrateu さんによる
Possibilities include: Cheap no-name battery from Amazon, damaged DC-in board (sometimes related to cheapo batteries), broken AC-adapter (MagSafe) cable/connector. About This Mac -> System Report -> Power will tell all about battery and charging circuit. (Just remember to refresh or re-open window after every change to get accurate results.) Recommend NuPower replacement batteries from OWC ($88U.S.)
MotorMac さんによる
Im not a pro at macs so ill ask if the DC is damaged, will it than run with a magSafe connected
magSafe should be fine as it is running when connected on magSafe just fine
Battery was around 60$ (55€)
So how big is the possibility that the battery is broken ?
Nenadbrateu さんによる
